2700C Cần giúp ạ !
Thảo luận trong 'SỬA CHỮA PHẦN MỀM.' bắt đầu bởi VietSon_QNgãi, 6/3/16.
  1. 6/3/16 lúc 13:53
    VietSon_QNgãi
    VietSon_QNgãi
    nhận máy lên nokia tắt e chạy lại ok nhưng vẫn vậy ạ ! ae xem giúp log lỗi chỗ nào với ạ !
    Log ạ !
    DLL not found...
    BB5 Easy Service Tool v1.14.1 (c) Infinity-Box Team Ready
    Connect phone on selected interface...
    Selected FlashSettings : Dead-Test
    Check FlashFiles, Please, wait...
    Files Set for Flashing :
    Flashing phone now...
    Check files done...
    -> SWversion check skipped : Dead mode selected
    -> Custom flashing in dead mode active!
    -> Phone will boot in normal mode after flash!
    Getting product info...
    Dead Mode is Selected
    Waiting for USB device...
    --- Press phone's power button or insert cable & charger! ---
    Connection opened successfully
    Waiting for communication response.
    [BB5 FLASH]: Can't verify Bootrom :( Try again...
    -> Error answer from BootRom
    -> 1. Try make battery charge
    -> 2. Try insert charger, without pressing poweron
    -> 3. Try change USB port, if driver hang - restart PC
    -> Error while flashing... :(
    Check files done...
    [BB5 FLASH]: Bootrom Ok!
    RAP_PUB: 16C0000CE64B68507B362D443303AD184EFCEA70
    CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723
    PatchRAWLoader: Patched OK
    Processing RAWLOADER...
    Processing UPDAPP...
    Processing PASUBTOC...
    TIME : Boot time : 00:00:00
    Reopening the connection...
    Waiting for response: 30
    ADL -> [2nd] changing...
    ADL Server confirm flashmode!
    ADL : Check data
    ADL : Data accepted
    ADL : ASIC CMT select Ok
    ===Flashing [MCU]===
    Erase : Processing rm561__09.98.mcusw
    Found 6 areas to erase
    Erasing area 0x00000000 - 0x000006BF, NOR, CMT
    Result: 0000
    Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT
    Result: 0000
    Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT
    Result: 0000
    Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT
    Result: 0000
    Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT
    Result: 0000
    Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT
    Result: 0000
    TIME : Erase time : 00:03:08
    Write : Processing rm561__09.98.mcusw
    Total 1256 [1256/0/0] blocks to write, writing...
    CMT : Writing Hash CERT [NOLO]
    CMT : Writing Hash CERT [KEYS]
    CMT : Writing Hash CERT [PRIMAPP]
    CMT : Writing Hash CERT [PASUBTOC]
    CMT : Writing Hash CERT [PAPUBKEYS]
    CMT : Writing Hash CERT [UPDAPP]
    CMT : Writing Hash CERT [DSP0]
    CMT : Writing Hash CERT [MCUSW]
    TIME : Write time : 00:00:59
    MCU Write done
    ===Flashing [PPM]===
    Erase : Processing rm561__09.98.ppm_v
    Found 1 areas to erase
    Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT
    Result: 0000
    TIME : Erase time : 00:01:17
    Write : Processing rm561__09.98.ppm_v
    Total 442 [442/0/0] blocks to write, writing...
    TIME : Write time : 00:00:21
    PPM Write done
    ===Flashing [CNT]===
    Checking content info...
    Check Image : Content size is 128k, use direct write mode
    Erase : Processing rm561__09.98.image_v_blac
    Found 2 areas to erase
    Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT
    Result: 0000
    Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT
    Result: 0000
    TIME : Erase time : 00:06:35
    Write : Processing rm561__09.98.image_v_blac
    Total 872 [872/0/0] blocks to write, writing...
    TIME : Write time : 00:00:43
    CNT Write done
    ADL : End flashing
    Flashing done!
    Total flash time : 00:13:06
    Reboot phone now...
    Afterflash not selected, skip
    Done!
    Elapsed: 00:13:16
  2. 6/3/16 lúc 13:55
    P-H_mobile
    P-H_mobile
    đa số dòng này thường lỗi cặp nhà lầu,mà thay cặp khác thì xác định trả cho rồi
  3. 6/3/16 lúc 13:57
    transy
    Super Moderator
    transy
    Tháo main xem con flash hiệu gì, nếu Intel thì còn có khả năng, còn Samsung thì chia tay thay cặp.
  4. 6/3/16 lúc 14:03
    VietSon_QNgãi
    VietSon_QNgãi
  5. 6/3/16 lúc 14:09
    transy
    Super Moderator
    transy
    Flash trên là intel, sau khi flash xong thử tháo camera, hoặc ic Blutooth xem lên được không.
  6. 6/3/16 lúc 14:12
    VietSon_QNgãi
    VietSon_QNgãi
    Tháo cam done luôn anh ơi !
