Unlock Security Code & Pattern Lock Remove All Sony Xpreia
Thảo luận trong 'SỬA CHỮA PHẦN MỀM.' bắt đầu bởi Star, 29/11/14.
  1. 29/11/14 lúc 10:55
    Star
    Super Moderator
    Star
    Mở khóa mã bảo mật và Khóa hình vẽ chỉ cần 5s mà không cần phải flash full nhanh gọn lẹ an toàn không lo mất boot ... Support All Sony Xperia Android
    Anh em tải về múc bằng flashtool
    All Android phone ( Files 80+ ....)
    Download here
    Pass : Vietfones
    list files
    Xperia Zr C5502 lock remove.ftf
    LT18i lock remove.ftf
    Xperia LT18a lock remove.ftf
    LT22i lock remove.ftf
    LT26i lock remove.ftf
    LT28i lock remove.ftf
    LT29i lock remove.ftf
    Xperia Z1 C6602 lock remove.ftf
    Xperia L C2104 lock remove.ftf
    Xperia E1 Dual D2105 lock remove.ftf
    Xperia E1 D2005 lock remove ftf
    Xperia M C1904 lock remove.ftf
    Xperia M C1905 lock remove.ftf
    Xperia SP C5302 Lock Remove.ftf
    Xperia Sp C5303 lock remove.ftf
    Xperia Tipo St21i lock remove.ftf
    W8 Walkman E16i lock remove.ftf
    Xperia M Dual C2004 lock remove.ftf
    Xperia M Dual C2005 lock remove.ftf
    Xperia L C2105 lock remove.ftf
    Xperia Arc LT15i Lock Remove.ftf
    WT19a Walkman lock remove.ftf
    WT19i Walkman lock remove.ftf
    Xperia Miro St23i lock remove.ftf
    Xperia X10 mini pro U20i lock remove.ftf
    Xperia X10 mini pro U20a lock remove.ftf
    Xperia X8 E15a lock remove.ftf
    Xperia X8 E15i lock remove.ftf
    Xperia X10a lock remove.ftf
    Xperia X10i lock remove.ftf
    Xperia X10 mini E10a lock remove.ftf
    Xperia X10 mini E10i lock remove.ftf
    Xperia M2 Aqua D2403 LTE-A lock remove.ftf
    Xperia M2 Dual D2302 lock remove.ftf
    Xperia T2 Ultar Dual lock remove.ftf
    Xperia E C1504 lock remove.ftf
    Xperia Play R800i lock remove.ftf
    Xperia U St25i lock remove.ftf
    Xperia SL Lt26ii lock remove.ftf
    Xperia V Lt25i lock remove.ftf
    Xperia P Lt22i lock remove.ftf
    Xperia J St26i lock remove.ftf
    Xperia Z1 compact LTE-A D5503 lock remove.ftf
    Xperia E C1505 lock remove.ftf
    Xperia E Dual C1604 lock remove.ftf
    Xperia E Dual C1605 lock remove.ftf
    Xperia Z C6602 lock remove.ftf
    Xperia Ray St18i lock remove.ftf
    Xperia Neo Mt11i lock remove.ftf
    Xperia Neo MT25i Lock Remove.ftf
    Xperia Sola MT27i Lock Remove.ftf
    Xperia C C2305 lock remove.ftf
    Xperia Z1 C6903 lock remove.ftf
    Xperia Z3 Compact LTE-A D5803 lock remove.ftf
    Xperia E3 Dual D2212 lock remove.ftf
    Xperia T Lt30p lock remove.ftf
    Xperia C3 Dual D2502 lock remove.ftf
    Xperia Go St27i lock remove.ftf
    Xperia M2 D2303 lock remove.ftf
    Xperia Z2 D6503 lock remove.ftf
    Xperia C3 D2533 lock remove.ftf
    Xperia Z3 D6653 lock remove.ftf
    Xperia Z3 D6633 lock remove.ftf
    Xperia T3 D5103 lock remove.ftf
    Xperia ZL C6503 lock remove.ftf
    Xperia mini pro SK17i lock remove.ftf
    Xperia Ultra C6802 lock remove.ftf
    Xperia Z Ultra C6833 lock remove.ftf
    Xperia Z2 D6543 Lock Remove.ftf
    Xperia Z2 D6502 Lock Remove.ftf
    Xperia Z2 D6503 Lock Remove.ftf
    Xperia E3 D2203 Lock Remove.ftf
    Xperia E4 Dual E2115 lock remove.ftf
    Xperia E4 Dual E2124 lock remove.ftf
    Xperia E4g E2043 lock remove.ftf
    Xperia E4g E2033 lock remove.ftf
    Xperia Z3 SOL26
    Xperia ZL2 SOL25
    Xperia Z Ultra SOL24
    Xperia Z1 SOL23
    Xperia UL SOL22
    Xperia M4, C4, Z4 Tablet (anh em chú ý kẻo dính đạn)
    • E2312
    • E2303
    • E2333
    • E2353
    • E2306
    • E2363
    • E5333
    • SGP712
    • SGP771
    Chi tiết ở đây : Link
    Update .........
    Chỉnh sửa cuối: 5/7/15
  2. 29/11/14 lúc 10:57
    MT mobile
    V.I.P
    MT mobile
    Thanks em, kèo thơm quá.
  3. 29/11/14 lúc 10:58
    minhtanbt
    minhtanbt
    pass là gì vậy anh.:D
  4. 29/11/14 lúc 11:00
    goldenfish
    goldenfish
    ngon quá format mỗi cái userdata, khỏi phải chạy lại hết 1 đống
  5. 29/11/14 lúc 11:03
    long_vân™
    long_vân™
    cho em xin cái pass load về chờ kèo . thank smod
  6. 29/11/14 lúc 11:05
    hieumobile81
    hieumobile81
    Sao em không dow được vậy?
  7. 29/11/14 lúc 11:07
    ĐT-Vạn-Phát
    ĐT-Vạn-Phát
    bấm vô load báo thế này .
  8. 29/11/14 lúc 11:09
    langtu_
    langtu_
    Cũng bị như trên :confused:
  9. 29/11/14 lúc 11:16
    Star
    Super Moderator
    Star
    @all định dạng file .tft lên mấy cái trình duyệt giở hơi nó báo vậy ;) kệ nó bấm bỏ qua hoặc sử dụng trình duyệt Internet Explorer:D
  10. 29/11/14 lúc 11:19
    hoangthanhpro
    hoangthanhpro
    chia sẻ luôn cả cái tool đi anh Ngọc đã thương thì thương cho chót.thanks anh
  11. 29/11/14 lúc 11:21
    ThiênTuấn_VFS
    ThiênTuấn_VFS
    :-* Qua Good. Sony thì không chơi 3 ngón được,nhiều lúc flash Full file ớn ăn,nhất là bằng tool. Nhanh gọn nhẹ,bớt nguy hiểm cho AE.
  12. 29/11/14 lúc 11:23
    langtu_
    langtu_
    Thanks mod, done roi :D
  13. 29/11/14 lúc 11:25
    Xuân Toàn
    Xuân Toàn
    thanks bác thế này thì ngon rồi, e vẫn hay dùng file gốc đánh dấu bỏ chọn hết đi còn mỗi 2 mục giống Mod mà có cây đc cây treo lại phải full flash, chắc do ko trùng phiên bản trong máy
  14. 29/11/14 lúc 11:25
    Star
    Super Moderator
    Star
    Chờ chút đang up.... :D
  15. 29/11/14 lúc 11:26
    Trần Quốc Lợi
    Trần Quốc Lợi
    Lại có kèo thơm tay ko bắt cốp.........
  16. 29/11/14 lúc 11:36
    AnhDuy mobile
    AnhDuy mobile
    thơm như mía lùi :eek:
  17. 29/11/14 lúc 11:37
    hoangmobile 86
    hoangmobile 86
    ngon ngọt như mía thanks mod
  18. 29/11/14 lúc 12:03
    AnhDuy mobile
    AnhDuy mobile
    smod , cho xin cái tool luôn nha bác :-*
  19. 29/11/14 lúc 12:09
    thanhhuyenmobi
    thanhhuyenmobi
    thank anh đã chia sẽ
  20. 29/11/14 lúc 12:13
    Star
    Super Moderator
    Star
  21. 29/11/14 lúc 12:22
    thanhxuanmobi
    thanhxuanmobi
    khó load quá anh em nào load được đưa mediafire đi
  22. 29/11/14 lúc 13:11
    NhựtTiến@
    NhựtTiến@
    Trước khi flash lock remove anh em read infor máy xem có cung ver ko nhé :D ko là ăn lỗi force close nhé :mad:
  23. 29/11/14 lúc 13:28
    Hải Sứt
    Hải Sứt
    Cảm con bà ơn bác cảnh báo khựa khựa !
  24. 29/11/14 lúc 13:51
    mobifones
    mobifones
    nHIỀU QUÁ, TẠM THỜI AD FILE VÀO TÀI KHOẢN CUẢ NICK, khi nào cần lấy về cho tiện
  25. 29/11/14 lúc 14:01
    thjnhtran263
    thjnhtran263
    load done rồi...đúi như củ chúi..tạo thành file zip load về 1 lần rồi bung ra cho tiện thớt ơi.
  26. 29/11/14 lúc 14:04
    Star
    Super Moderator
    Star
    Sẽ còn update dần dần từng version cho từng model khi có ver mới......:D
  27. 29/11/14 lúc 14:07
    Star
    Super Moderator
    Star
    Cứ chọn file đúng android version là done ...Android 4.1.2, 4.2.2, 4.4.2 ......
  28. 29/11/14 lúc 14:21
    qhtmobilehuy
    qhtmobilehuy
    hót thank,,,,,,,,,,,,,,,,,,,,,,,,
    Note : Ko spam đè keypad trong khu vực kĩ thuật
  29. 29/11/14 lúc 14:26
    Thienbaogsm
    Thienbaogsm
    kèo hot Thanks smod :mad:
  30. 29/11/14 lúc 14:33
    HongVinhMobile
    HongVinhMobile
    1. add vào folder của mình.
    2. Cài app 4shared kéo cả đám về cho lẹ.
  31. 29/11/14 lúc 14:56
    hung1983
    hung1983
    chỉ giùm đi bạn ơi,chứ load từng cái chết chắc quá:D
  32. 29/11/14 lúc 17:13
    tungmobile12
    tungmobile12
    pé pas với anh ơi,rất hữu ích,thanks anh nhiều
  33. 29/11/14 lúc 17:14
    AnhDungUSA
    AnhDungUSA
    Xong hết kèo luôn rồi :D
  34. 29/11/14 lúc 18:24
    3Gmobile
    3Gmobile
    Vừa done 1 em Xperia M_C1905 nhanh gọn, thanks Mod xì kèo...:eek:
  35. 29/11/14 lúc 18:40
    HoaPhượngĐỏ™
    HoaPhượngĐỏ™
    đánh dấu cái .
  36. 2/12/14 lúc 22:17
    Dê Tiên Sinh
    V.I.P
    Dê Tiên Sinh
    rất bổ ích cho anh em mới vào nghề,cả anh em chưa rành về Sony. Thank Smod chia sẽ
  37. 2/12/14 lúc 22:29
    Tạ Hồng Phỉ
    Tạ Hồng Phỉ
    thank Smod chia sẽ,lưu lại chờ kèo
  38. 3/12/14 lúc 01:53
    thinh182009
    thinh182009
    Rảnh làm tiếp các model khác :'''
  39. 3/12/14 lúc 07:58
    mrscorpion
    mrscorpion
    cũng đang tổng hợp mấy cái file này lúc tải các bundle về từ flashtool mà cái ổ cứng nó gần đầy mất, may quá có bác thớt, thank
    Tiện thể hướng dẫn ae chưa biết, cách lưu folder và tải về bằng 4shared tool luôn:
    1. Ae cần tạo 1 tài khoản tại http://www.4shared.com/
    2. Làm tiếp như sau:
    tùy theo dung lượng của thư mục mà thời gian sao chép qua tài khoản của bạn nhanh hay chậm, như trên hình bấm copy rồi mà chưa thấy chuyển, :D
    đang qua nhưng qua chưa hết, xem phần dung lượng:
    NhutGsm thích bài này.
  40. 13/12/14 lúc 11:06
    TN_Service
    V.I.P
    TN_Service
    SO-04E ae lấy file của C5502 ở trên nhé!
