Thanh lí chân đế máy quay chuyên nghiệp ZEISS/BOSH FULL-SIZE TRIPOD WITH 3-WAY HEAD, FT-6302, WITH RUGGARD PADDED CASE Đầy đủ phụ kiện, bao đựng, đẹp như mới. Giá 1.650.000 vnđ {} {} {} {} {} Zeiss/Bosh Full-Size Tripod with 3-Way Head, Model FT-6302, Discontinued PLUS Brand New 27" Ruggard Black, Nylon Padded Case, Yellow Embroidery Up for your consideration is this rare and discontinued heavy duty tripod. It is used with some minor cosmetic flaws in very good overall condition. This is a quality tripod still in great mechanical working order and it comes with a NEW Ruggard tripod padded case. Below are the specifications for both items. Tripod Overview This heavy-duty Zeiss all-aluminum tripod is designed to fully support the Diascope line of spotting scopes. It's rated to support up to 6.6 lbs. Each leg can be adjusted individually, at three different leg-angle settings. Specifications Maximum Height 57.2" ( 145.3 cm ) Maximum Height w/o Column Extended 49" ( 124.5 cm ) Minimum Height 16.8" ( 42.7 cm ) Folded Length 23" ( 58.4 cm ) Load Capacity 6.6 lbs ( 3 kg ) Leg Sections 4 Leg Lock Type Flip lever Independent Leg Spread Yes Center Column Sections 1 Center Column Type Sliding Center Brace No Spiked Feet No Head Type 3-Way Pan/Tilt Head Head Mount Thread Size 3/8"-16 Weight 6.5 lbs ( 2.880 kg ) Liên hệ Thế Anh: 0903756388 Đc:13m, Cư Xá Ngân Hàng, P. Tân Thuận Tây, Q.7
