sony c3 D2502 cần giúp đỡ
Thảo luận trong 'SONY ANDROID' bắt đầu bởi anhtuhonglinh, 8/7/17.
  1. 8/7/17 lúc 19:03
    anhtuhonglinh
    anhtuhonglinh
    em nhận cây máy khách đem tới tình trạng như vầy:
    flash toll chạy báo như thế này:
    08/000/2017 20:00:16 - INFO - Selected Bundle for Sony Xperia C3 (D2502). FW release : 19.4.A.0.182. Customization : Customized VN
    08/000/2017 20:00:16 - INFO - Preparing files for flashing
    08/001/2017 20:01:34 - INFO - Please connect your device into flashmode.
    08/001/2017 20:01:53 - INFO - Device connected in flash mode
    08/001/2017 20:01:53 - INFO - Opening device for R/W
    08/001/2017 20:01:54 - INFO - Reading device information
    08/001/2017 20:01:54 - INFO - Phone ready for flashmode operations.
    08/001/2017 20:01:54 - INFO - Opening TA partition 2
    08/001/2017 20:01:54 - INFO - Current device : D2502 - YT910Y7XQ7 - 1288-9436_R2B - 1286-5871_19.2.A.0.391 - GLOBAL-HSPA_19.2.A.0.391
    08/001/2017 20:01:54 - INFO - Closing TA partition
    08/001/2017 20:01:54 - INFO - Start Flashing
    08/001/2017 20:01:54 - ERROR - root : this bundle is not valid
    08/001/2017 20:01:55 - INFO - Processing loader.sin
    08/001/2017 20:01:55 - INFO - Checking header
    08/001/2017 20:01:55 - INFO - Flashing data
    08/001/2017 20:01:56 - INFO - Loader : S1_Root_f82d - Version : LOADER_RELEASE_MSM8X26_31_AID_4 / Boot version : S1_Boot_MSM8x26_LA1.0_1022 / Bootloader status : ROOTABLE
    08/001/2017 20:01:56 - INFO - Transfer buffer size : 262144
    08/001/2017 20:01:56 - INFO - Parsing boot delivery
    08/001/2017 20:01:56 - ERROR - root : this bundle is not valid
    08/001/2017 20:01:56 - INFO - You must have the according fsc script to flash this device.
    08/001/2017 20:01:56 - INFO - Flashing finished.
    08/001/2017 20:01:56 - INFO - Please unplug and start your phone
    08/001/2017 20:01:56 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
    xin thỉnh giáo các bác cao kiến ạ c33k)
    @: Không viết bài bằng font màu đỏ, phạm quy, đã edit!!!
  2. 8/7/17 lúc 20:49
    transy
    Super Moderator
    transy
    Tải ver cao nhất về up lại thử, ver chạy thấp quá !! Hoặc có setool thì uprom dễ thành công hơn.
  3. 8/7/17 lúc 21:06
    congbinhqn
    congbinhqn
    bác tính root ah,chưa unlockbootloader sao mà nạp
  4. 9/7/17 lúc 10:49
    anhtuhonglinh
    anhtuhonglinh
    em đã tải ver cao nhất về làm, chạy full ok nhưng chớp tắt logo ko lên dc, vẫn lỗi.
    hình log đây ạ:
    cho em hỏi ngu là trong setting mình cần check những gì ạ:
    em flash rom bác ạ. máy tình trạng nhận là treo như hình rồi, em nạp lỗi ko dc.
    trong trường hợp này mình có giải pháp nào xử lý ko ạ?
  5. 9/7/17 lúc 11:01
    congbinhqn
    congbinhqn
    stick vào applogs - userdata - cust reset - fota reset rồi nạp lại lần nữa
  6. 9/7/17 lúc 11:07
    transy
    Super Moderator
    transy
    Ver đang chạy vẫn chưa max, ver max hiện tại là 19.4.A.0.182.
  7. 9/7/17 lúc 11:10
    anhtuhonglinh
    anhtuhonglinh
    bác có bản rom đó luôn ko ạ, cho em xin link dow nạp thử luôn xem dc ko ạ
  8. 9/7/17 lúc 11:21
    CuDuy-VF
    Super Moderator
    CuDuy-VF
  9. 9/7/17 lúc 11:23
    anhtuhonglinh
    anhtuhonglinh
    cám ơn các bác.
    em đang load về, xong em nạp chạy thử.
  10. 9/7/17 lúc 11:52
    anhtuhonglinh
    anhtuhonglinh
    em đã nạp bản cao nhất, kết quả vẫn ko dc
    trong đây mình check thế nào vậy bác:
  11. 9/7/17 lúc 12:28
    CuDuy-VF
    Super Moderator
    CuDuy-VF
    Thấy chạy được đâu.
  12. 9/7/17 lúc 12:44
    anhtuhonglinh
    anhtuhonglinh
    thì em nói là kết quả ko dc mà bác.
    ko biết lỗi có liên quan phần cứng ko.
