Reset FRP lOCK on SAMSUNG 2016
Thảo luận trong 'SAMSUNG ANDROID' bắt đầu bởi huuloimobile, 29/3/16.
  1. 29/3/16 lúc 13:30
    huuloimobile
    huuloimobile
    Gặp kèo ae tes thử nhé
    • SET WIFI ON PHONE AFTER FACTORY RESET
      -INSTALL sidesync ON PC FIRST
      -OPEN SIDESYNC AND CONNECT USB TO PHONE(PHONE IS ON NORMAL MODE)
      -SELECT CHROME AFTER CONNECT USB TO PHONE
      -TYPE http://www.huadongle.ir/frp/hua.apk IN CHROME AND THEN PRESS GO
      -WAIT FOR DOWNLOAD APK
      -PRESS BACK/OK AND GOTO GALAXY APPS FROM CHROME AFTER DOWNLOAD APK
      -PRESS AGREE IN GALAXY APPS
      -SELECT SEARCH IN GALAXY APPS
      -TYPE ES FILE EXPLORER
      -SELECT INSTALL
      -PHONE NEED NEW SAM ACC
      -CREATE NEW ACCOUNT FOR PHONE AND SIGN IN
      -INSTALL ES FILE EXPLORER AFTER SIGN IN
      -GOTO ES FILE EXPLORER FOLDERS/DOWNLOAD
      -INSTALL HUA.APK AND THEN OPEN
      -GOTO BACKUP/RESET AND AFTER OPEN HUA.APK
      -SELECT FACTORY DATA RESET AND WAIT FOR NEW REBOOT
      -DONE
      -SOME NEW PHONES NEED ENBALE DEVELOPER OPTIONS AND THEN OEM LOCK FOR RESET AFTER INSTALL APK
      -USE DOWNGRAD WITHOUT SELECT BOOTLOADER FILE(IN ODIN)FOR A5 A7 A3 2016 PHONES IF DEVELOPER OPTIONS IS HIDDEN AFTER ACTIVE ​
  2. 29/3/16 lúc 13:33
    phuctoanap
    phuctoanap
    thank anh nếu ok thì kèo này quá hót
  3. 29/3/16 lúc 13:36
    Phan Vững™
    Phan Vững™
  4. 29/3/16 lúc 14:57
    Bắc Ninh ISTORE
    Bắc Ninh ISTORE
  5. 29/3/16 lúc 15:06
    trangthanh-386
    Respected Mod
    trangthanh-386
    làm sao mà bấm unock OEM thì mới ok
  6. 29/3/16 lúc 16:43
    goldenfish
    goldenfish
    New ver nó block cái developer option rồi, khôgn khả thi với cái này, chỉ test ok với phiên bản cũ và A3 2016
