mmc_read_blocks(0x0 , 1 ), Reason: CMD Timeout Error mong mọi người giúp đỡ!
Thảo luận trong 'THIẾT BỊ HỖ TRỢ SỬA CHỮA.' bắt đầu bởi action05, 27/8/17.
  1. 27/8/17 lúc 18:19
    action05
    action05
    Xin nhờ mọi người giúp đỡ, eMMC bị lỗi như vầy nạp lại FW không được Detect thì bị lỗi như hình, mong mọi người giúp đỡ
    EMMC CID : 1501004D4147324722222222EA774FD8
    EMMC CSD : D02701320F5903FFF6DBFFFF8A406062
    EMMC Manufacturer ID: 0015 , OEM ID: 0100
    EMMC Date: 04/2012 Rev.0x22
    EMMC NAME: MAG2G , S/N: 572713591
    EMMC NAME (HEX): 4D414732472000
    EMMC ROM1 (Main User Data) Capacity: 17592185589276 MB
    EMMC ROM2 (Boot Partition 1) Capacity: 14336 kB
    EMMC ROM3 (Boot Partition 2) Capacity: 14336 kB
    EMMC RPMB (Replay Protected Memory Block) Capacity: 19584 kB
    EMMC Permanent Write Protection: Yes
    EMMC Temporary Write Protection: No
    EMMC Password Locked: Yes
    Extended CSD rev 1.67 (MMC Unknown)
    Boot configuration [PARTITION_CONFIG: 0xc4] No boot partition configured.
    Boot bus config [177]: 0xe0 , width 1bit , Partition config [179]: 0xc4.
    H/W reset function [RST_N_FUNCTION]: 0x32
    High-capacity W protect group size [HC_WP_GRP_SIZE: 0x012f1800]
    Partitioning Support [PARTITIONING_SUPPORT]: 0x7f
    Device support partitioning feature
    Device can have enhanced tech.
    Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0xfb
    EMMC GP1 (Extended Partition 1) Capacity: -280971728MB
    EMMC GP2 (Extended Partition 2) Capacity: 1203150545MB
    EMMC GP3 (Extended Partition 3) Capacity: 2028816035MB
    EMMC GP4 (Extended Partition 4) Capacity: -967575710MB
    Backup saved: MAG2G _ 572713591_20170827_1815.extcsd
    mmc_read_blocks(0x1 , 1 ), Reason: CMD Timeout Error
    mmc_read_blocks(0x7FFFFFC870E270 , 1 ), Reason: CMD Timeout Error
    Partition table scan:
    GPT: not present
    Done.
    Untitled.
  2. 27/8/17 lúc 18:30
    Lê Anh VF
    Lê Anh VF
    a làm máy gì vậy? mmc lỗi thì thay sao cứu @@.
  3. 3/9/17 lúc 19:23
    action05
    action05
    Bác có cách lấy 1 emmc samsung khác nạp lại fw rồi đóng vào máy lên ko bác...
    Ví dụ em có con Sky A870 32GB lỗi emmc em muốn thay emmc Samsung máy khác 16GB nạp file ROM 1 - 2 - 3 vào nhưng vẫn không được, đã nạp fw và chỉnh lại boot 2 chỉnh lại RPMB : 4M rồi, nạp xong đóng vào vẫn không lên...
  4. 3/9/17 lúc 20:10
    Lê Anh VF
    Lê Anh VF
    từ 32 xuống 16 cũng ko phải là vấn đề,vấn đề ram có = hay ko ah a .kiếm con trùng ram và factory các kiêu update lại luôn rồi nạp dump.ko đc nữa e nghĩ bị cái khác ah
  5. 3/9/17 lúc 20:11
    duythangvn
    duythangvn
    tờ giấy nó thủng anh có kẻ được 1 đường thẳng liền mạch không ?
    Lê Anh VF thích bài này.
  6. 3/9/17 lúc 20:12
    Lê Anh VF
    Lê Anh VF
    Còn cái log phía trên mmc e thấy nó ngởm rồi á,kiếm con khác đi a @@
  7. 4/9/17 lúc 08:10
    Chung ATF
    Chung ATF
    câu chân pinout xún mass xong fix ok.
    tùy loại. 153 hoặc 162 hoặc 221 mà chân pinout nó nằm khác nhau.
  8. 4/9/17 lúc 13:49
    action05
    action05
    ok thanks các bác, e cũng đã thử rồi mà vẫn chưa đc, e nghĩ bị mất bit nào trên eMMC rồi
  9. 4/9/17 lúc 20:19
    vinhkiengiang
    vinhkiengiang
    99% con emmc này theo ông bà
  10. 4/9/17 lúc 20:37
    vanviet7785
    vanviet7785
    Easy jtat nó vậy có ufi bỏ vào up lai fw ok nhé
