[Chia sẻ]LG F180 convert kdz to oct and flash ok by mực
Thảo luận trong 'LG ANDROID' bắt đầu bởi goldenfish, 26/4/14.
  1. 26/4/14 lúc 18:02
    goldenfish
    goldenfish
    Convert trực tiếp từ KDZ ra nhe ACE :''' ngon rồi :'''
    Máy đưa vào bị treo ở fastboot do flash file trên support của octopus, lấy file kdz ra convert xong đập phát lên luôn......... :D
    Converting files...
    Unpacking "G:\DROID\TOOL\LG_EXTRACT\F180S20L_00.kdz"...OK
    Opening "C:\Users\DUYHA_~1\AppData\Local\Temp\F180S20L_00
    \F180S20L_00.dz"...OK
    Unpacking "PrimaryGPT"...OK
    Unpacking "modem"...OK
    Unpacking "sbl1"...OK
    Unpacking "sbl2"...OK
    Unpacking "sbl3"...OK
    Unpacking "aboot"...OK
    Unpacking "rpm"...OK
    Unpacking "boot"...OK
    Unpacking "tz"...OK
    Unpacking "misc"...OK
    Unpacking "system"...OK
    Unpacking "system1"...OK
    Unpacking "system2"...OK
    Unpacking "system3"...OK
    Unpacking "system4"...OK
    Unpacking "system5"...OK
    Unpacking "system6"...OK
    Unpacking "system7"...OK
    Unpacking "system8"...OK
    Unpacking "system9"...OK
    Unpacking "system10"...OK
    Unpacking "system11"...OK
    Unpacking "system12"...OK
    Unpacking "system13"...OK
    Unpacking "system14"...OK
    Unpacking "system15"...OK
    Unpacking "system16"...OK
    Unpacking "system17"...OK
    Unpacking "persist"...OK
    Unpacking "recovery"...OK
    Unpacking "BackupGPT"...OK
    Unpacking done. Processing files...
    Identifying sub-files...OK
    Creating destination file...OK
    Deleting temporary files...
    Deleting directory "C:\Users\DUYHA_~1\AppData\Local\Temp\F180S20L_
    00\"...
    Deleting file "C:\Users\DUYHA_~1\AppData\Local\Temp\F180S20L_00
    \aboot.bin"...OK
    \BackupGPT.bin"...OK
    \boot.bin"...OK
    \misc.bin"...OK
    \modem.bin"...OK
    \parts.bin"...OK
    \persist.bin"...OK
    \PrimaryGPT.bin"...OK
    \recovery.bin"...OK
    \rpm.bin"...OK
    \sbl1.bin"...OK
    \sbl2.bin"...OK
    \sbl3.bin"...OK
    \system.bin"...OK
    \tz.bin"...OK
    Directory "C:\Users\DUYHA_~1\AppData\Local\Temp\F180S20L_00\"
    succesfully deleted!
    Firmware convert done!
    Platform: LG Qualcomm
    Selected port: COM9
    Selected model: F180L
    Searching Diagnostic Ports...OK
    Reading info...OK
    Mode: Emergency
    Model ID: BS/J1U/1
    SW version: LGF180LAT-00-V20h-LGU-KR-JAN-04-2013+0
    Product ID: PT01S130107002859
    IMEI: 354282-05-043224-0
    Opening "F180S20L_00.oct"...OK
    Initializing flash...OK
    Reading partition...OK
    Writing PrimaryGPT...OK
    Formating userdata...OK
    Formating cache...OK
    Writing modem...OK
    Writing sbl1...OK
    Writing sbl2...OK
    Writing sbl3...OK
    Writing aboot...OK
    Writing rpm...OK
    Writing boot...OK
    Writing tz...OK
    Writing system...OK
    Writing persist...OK
    Writing recovery...OK
    Writing BackupGPT...OK
    Finalizing...OK
    Writing firmware done!
  2. 26/4/14 lúc 18:23
    truongtribao
    truongtribao
    F180 + E975 thường chạy FlashTool online ko có đc nên mình thường chạy KDZ_FW_UPD offline là done ngay .
  3. 26/4/14 lúc 18:29
    goldenfish
    goldenfish
    Cách này thì ai trong tình thế mới hiểu dc sự tiện lợi của mực :p
  4. 26/4/14 lúc 18:34
    truongtribao
    truongtribao
    Ở nhà em cũng có con mực mà em chưa bao giờ gập trường hợp này lần nào hi vọng sẽ đc gập trong thời gian sớm nhất để lạc hậu quá . :D
  5. 26/4/14 lúc 18:35
    Lộc Phát GSM
    Lộc Phát GSM
    thank anh chờ kèo......;)
  6. 26/4/14 lúc 19:37
    unlockdtdd
    Super Moderator
    unlockdtdd
    Chuẩn nè, file của Oc nó có cái hay riêng, nhất là mấy con samsung cần nạp Radio :D
  7. 26/4/14 lúc 19:42
    thinh1982
    thinh1982
    đúng rồi anh cá rô nói đúng đó bạn
  8. 26/4/14 lúc 20:09
    Trường Apple ĐN
    Trường Apple ĐN
    chắc kèo này lượm 300k nhỉ . ..
  9. 26/4/14 lúc 21:15
    Trọng Kinh Môn
    Trọng Kinh Môn
  10. 26/4/14 lúc 21:43
    MinhTri-386
    Respected Mod
    MinhTri-386
    Con F260s quất bằng KDZ đi bụi luôn,lên logo reset lại,cũng may mà cứu được bằng file *.tot
  11. 26/4/14 lúc 21:46
    MinhTri-386
    Respected Mod
    MinhTri-386
    P/S:Mất 50k tiền full dump mà éo được
  12. 26/4/14 lúc 22:09
    goldenfish
    goldenfish
    Cơ bản là tot với oct nó như như nhau, oct nó làm trò với chỉnh lại 1 chút cấu trúc file để khỏi bị....xài ké :D trò LG Flash tool chơi file tot với dll chưa thành công dc con thứ 2................ kc/
  13. 14/5/14 lúc 17:50
    Dzung_mobile
    Dzung_mobile
    Mình muốn bổ sung thêm thông tin tý cho đầy đủ: Thằng KDZ nó không giải được bài toán hơn 1Gb cho 1 file nên bài này của bạn đang thiếu chỗ đó, còn mực thì đến ver 1.52 mới support convert KDZ.
  14. 14/5/14 lúc 17:53
    ThienTran_GSM
    ThienTran_GSM
    nãy úp con F180 qua KDZ hok được a.android hem rành lắm.hix
  15. 14/5/14 lúc 17:55
    goldenfish
    goldenfish
    Bạn dùng octopus convert trực tiếp sang file oct rồi flash với octopus lg tool nhé
  16. 14/5/14 lúc 17:57
    ThiênLong
    V.I.P
    ThiênLong
    mấy dòng LG này đúng là rối thiệt :p
  17. 14/5/14 lúc 17:58
    Hung_79hn
    V.I.P
    Hung_79hn
    Vừa up bằng KDZ 2 em F180 1 em F100L ok . Chắc sài chưa quen :D
  18. 14/5/14 lúc 18:00
    Rượu&Tình
    Rượu&Tình
    tool chỉ chạy thường thôi nhưng con lỗi sao chạy dc. hôm em gặp 1 con khóa MK kiểu như lock nhà mạng ý toàn chữ hàn chạy ko KDZ ko hết phải lôi octopus ra flash ok luôn
    file tot cho anh AE conver đỡ vất vả >> http://pan.baidu.com/share/link?shareid=329071&uk=3978960970
  19. 14/5/14 lúc 18:02
    ThienTran_GSM
    ThienTran_GSM
    trước e dùng KDZ úp mấy con này suốt vẫn bình thường.nãy mang ra up con f180 lên E975 hok đc,úp thử rom gốc củng hok được luôn :cry:
    p/s : có phải dùng cách gì fix lỗi để úp offline kg a ? sẳn tiện chỉ e luôn,cái này e gà :D
  20. 15/5/14 lúc 11:12
    Dzung_mobile
    Dzung_mobile
    Mod có cái file cũ nên mới ok, chắc là down lâu rồi. Còn nếu muốn thử thì mod vào down bản mới nhất cho F180 rồi quẳng log lên cho ae xem và học hỏi nhé. Cảm ơn Mod nhiều!
  21. 15/5/14 lúc 11:19
    CuDuy-VF
    Super Moderator
    CuDuy-VF
    Up bằng KDZ , thì tìm lại bài fix KDZ làm theo sẽ up ok . mới up cây F180 cái nay mấy hôm bằng KDZ ok. S K hay L không nhớ nữa
  22. 24/11/17 lúc 08:47
    takihuntran
    takihuntran
    em có con mực, nhận khách cây máy LG LS 676 mà trong file support của mực không có dòng máy này, chỉ support LS 675, kiếm trên mạng được file .TOT về cho mực ăn rồi chết boot luôn, add có cách nào cứu boot cho bé này bằng mực không chỉ bảo em với, thank's
  23. 24/11/17 lúc 18:31
    goldenfish
    goldenfish
    sao ko kiếm kdz của 676 rồi convert. brick thì kiếm riff repair hoặc medusa repair boot lại thôi
    riêng octopus nay cho phép flash thẳng từ kdz ở 1 số dòng thông dụng rồi, ae thoải mái mà làm
    takihuntran thích bài này.
