6300 mở nguồn treo nokia flash không dc cần giúp
Thảo luận trong 'CÁC DÒNG ĐIỆN THOẠI PHỔ THÔNG' bắt đầu bởi phanthieno, 8/6/18.
  1. 8/6/18 lúc 10:02
    phanthieno
    phanthieno
    Như tiêu để e flash không dc mong các anh giúp
    đây là log của em nó:
    ATF Software Version v12.67
    ATF Box FBUS Flash Started...
    Number of Image Files: 3
    Basic Phone Information
    MCU Version: V 05.00 27-04-07 RM-217 (c) Nokia.
    IMEI Plain : 357671017758605
    IMEI Spare : A357671017758600
    IMEI SV : 33576710177586008F
    Phone Model: Nokia 6300
    Category : Classic Phone
    Phone Type : RM-217
    PM 308 Found...
    Simlock Data Saved to : C:\AdvanceBox Turbo Flasher\Nokia\Backup\357671017758605\SL1_certificate_V 05.00 27-04-07 RM-217 (c) Nokia._357671017758605_Not Locked_095922.pm
    Changing MODE : FLASH
    Booting Phone via FBUS...
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded First Time
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 010C1921
    ID DWORD 4 : 01001101
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000232
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000353
    4 PUBLIC_ID 12
    ID DWORD 0 : 2AD00008
    ID DWORD 1 : 58490052
    ID DWORD 2 : 65D49E1C
    ID DWORD 3 : 598F055B
    ID DWORD 4 : 5A18DBD1
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 191EC665
    CRC 1 : DFAAF68F
    Checksum C1
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    Boot File - Version 010.042.00
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    SearchForBootstrap_DCT5 : No Error - 0 (0x00)
    Secondary Loader Sent...
    ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
    MCU_CONFIGURATION_RESPONSE_BB5:
    MessageID : 03
    SubBlocks : 03
    1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 2208 -> K8F5615ETM/K5G5629ATD
    Extended/Fixed ID : 0000
    Revision ID : 6921
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : 00000000000000000000
    3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Manufacturer Code : FFFF -> Flash
    Device ID : 0000 -> BAD FLASH TYPE
    Revision ID : 0000
    Checksum : 00
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :00EC DevID :2208 ExtID :0000 RevID :6921
    Flash Descriptor
    Device ID : 2208
    Revision ID : 0000
    Size : 02000000 (32 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    Algorithm File - Version 010.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
    PAPUB_KEYS_HASH_REQ_BB5
    PhoneInfoRequest_BB5 (Asic Index 00 )
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    7F7E6491E8D30494B45630BB3A8599F4E1C674C9
    PHONE FIRMWARE VERSION:
    START READING RPL DATA
    Reading : NPC (CMT)
    OK
    Reading : VARIANT (CMT)
    OK
    Reading : CCC (CMT)
    OK
    Reading : HWC (CMT)
    OK
    Reading : R&D (CMT)
    OK
    Reading : PARTNERC (CMT)
    PARTNERC : Empty
    Reading : MDM_KEYS (CMT)
    MDM_KEYS : Empty
    NPC CERTIFICATE INFORMATION (CMT):
    IMEI : 357671017758605
    PRODUCT CODE : 0537683
    BLUETOOTH ID : 00:1C:D6:95:2A:F2
    PUBLIC_ID : 2AD000085849005265D49E1C598F055B5A18DBD1
    PAPUB_KEYS_HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
    VARIANT CERTIFICATE INFORMATION (CMT):
    PRODUCT CODE : ÿÿÿÿÿÿÿ
    CCC CERTIFICATE INFORMATION (CMT):
    HWC CERTIFICATE INFORMATION (CMT):
    WARNING: PRODUCT CODES MISMATCH
    This might cause SECURITY TEST FAILED
    in Phones which require them to match
    FINISHED READING RPL DATA
    RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\357671017758605\357671017758605_095948.rpl
    Processing Image File :
    C:\Program Files (x86)\Nokia\Phoenix\Products\RM-217\rm217__07.30.mcusw
    CMT Type : BB5
    CMT Algorithm : BB5 ALGORITHM
    Secondary Sending Speed : 3250000 Hz
    Algorithm Sending Speed : 6500000 Hz
    Program Sending Speed : 6500000 Hz
    Message Reading Speed : 98000 Hz
    Number of Blocks : 944
    Entry Point : 0x453C
    Page Format : 128K
    Maximum Page Size : 0x00004000
    BootFlashModeDCT5Ex Failed
    Operations Failed....
  2. 8/6/18 lúc 10:07
    phanthieno
    phanthieno
    Có anh em nao giúp em với em cảm ơn nhiều ạ.
  3. 8/6/18 lúc 10:52
    huutri520744
    huutri520744
    dùng tool flash xem sao bạn
    phanthieno thích bài này.
  4. 8/6/18 lúc 11:44
    phanthieno
    phanthieno
    Tool cũng k dc anh ơi
