em chạy file này rồi ok nhưng không nên card found: A1B5CCE8 registered to: CycloneBox Connect phone on selected interface... Connect phone on selected interface... Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm429__03.56.mcusw PPM : rm429__03.56.ppm_i CNT : rm429__03.56.image_i Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006010C192101003000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1D000218BCE755501CD2D88EC40CB5D63B9D1735 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm429__03.56.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x014FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:07 Write : Processing rm429__03.56.mcusw Total 1037 [1037/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:37 MCU Write done ===Flashing [PPM]=== Erase : Processing rm429__03.56.ppm_i Found 1 areas to erase Erasing area 0x01500000 - 0x01BBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:31 Write : Processing rm429__03.56.ppm_i Total 376 [376/0/0] blocks to write, writing... TIME : Write time : 00:00:40 PPM Write done ===Flashing [CNT]=== Erase : Processing rm429__03.56.image_i Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01BC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:09 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm429__03.56.image_i Total 456 [456/0/0] blocks to write, writing... TIME : Write time : 00:00:44 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:07:50 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3610a Software Info: V 03.56 07-10-08 RM-429 (c) Nokia IMEI: 356785023067529 PPM version : Vp 03.56 07-10-08 RM-429 (c) Nokia I Product code: 0565035 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:08:58 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok
log chesh card found: A1B5CCE8 registered to: CycloneBox Connect phone on selected interface... Connect phone on selected interface... Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm429__03.56.mcusw PPM : rm429__03.56.ppm_i CNT : rm429__03.56.image_i Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006010C192101003000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1D000218BCE755501CD2D88EC40CB5D63B9D1735 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm429__03.56.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x014FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:07 Write : Processing rm429__03.56.mcusw Total 1037 [1037/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:37 MCU Write done ===Flashing [PPM]=== Erase : Processing rm429__03.56.ppm_i Found 1 areas to erase Erasing area 0x01500000 - 0x01BBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:31 Write : Processing rm429__03.56.ppm_i Total 376 [376/0/0] blocks to write, writing... TIME : Write time : 00:00:40 PPM Write done ===Flashing [CNT]=== Erase : Processing rm429__03.56.image_i Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01BC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:09 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm429__03.56.image_i Total 456 [456/0/0] blocks to write, writing... TIME : Write time : 00:00:44 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:07:50 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3610a Software Info: V 03.56 07-10-08 RM-429 (c) Nokia IMEI: 356785023067529 PPM version : Vp 03.56 07-10-08 RM-429 (c) Nokia I Product code: 0565035 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:08:58 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Read and Check phone data... ---------------------- RAP_BOOT: 0803000002010000 RAP_PUB: 1D000218BCE755501CD2D88EC40CB5D63B9D1735 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP_PAPUB: A32E417B72C365977BB436843861AB6E35608542 ---------------------- Live Test Ok! ---------------------- CNT sector : 128 kb ------------------------ SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL2 phone detected
