Trang 1/2 12 cuốicuối
Kết quả từ 1 tới 10 trên 15
  1. #1
    Senior Member bavi_gsm's Avatar
    Tham gia ngày
    Jun 2011
    Bài gởi
    2,332
    máy qua atf nạp die,nạp đi nạp lại không ok,qua cyclone ok.
    Establishing Connection with Box in Main Mode...
    Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
    Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
    Initiali**** box...
    Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
    Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
    Box Serial Number: C000758D
    HW Revision: B, Suitable for: Production, Case: 2011 - New Casing, MCU Manufacture Time: 2009, wk23 / wk19
    Initiali**** security card...
    Card Serial Number: D00D0368
    Card Firmware Revision: 010A
    Card is activated
    Box is activated
    Started box selftests procedure
    USB Voltage 4.93v PASSED
    MCU Voltage 3.29v PASSED
    Core Voltage 1.77v PASSED
    VBAT Voltage 0.01v PASSED
    VBAT Voltage 4.88v PASSED
    Box VPP disabled
    VPP Voltage 0.04v PASSED
    Internal Box VPP Enabled
    VPP Voltage 4.83v PASSED
    Box VPP disabled
    VPP Voltage 0.02v PASSED
    External Box VPP Enabled
    VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
    Box VPP disabled
    All box selftests passed!
    Super DCT4 Activation: TRUE
    XGold/Blackberry Service Running, Counter: 100
    Avaiable Physical Memory: 1.1023GB
    Avaiable Virtual Memory: 1.824GB
    Avaiable Pagefile: 3.1023GB
    Initiali**** FBUS...
    All initialized - Ready to work
    Retrieving Variants for Product RM-872 - wait...
    1 Variants Retrieved
    Processing pre flash tasks...
    Pre flash tasks finished, continuing...
    Processing rm872__03.58.mcusw (XGold2)...
    Checking rm872__03.58.mcusw...
    Flash file sorted Okay.
    1 file(s) embedded into image.
    Booting X-Gold via USB...
    If PC Can't detect any new device, probably your phone is erased. Do following if needed:
    1. Eject battery
    2. Eject cable
    3. Insert cable
    4. Insert battery
    5. Press power-on
    [Nokia USB Flashing Generic]: Port opened OK!
    X-Gold: Ready, MCU ID Block: 1FB300020303010100FF
    [PBL] : Ready
    [EBL] : Mode CC
    [EBL] : Quantum_Bootloader_10.53_M1S1
    [EBL] : Ready
    Setting Baudrate to 6500000bps...
    Baudrate Accepted (6500000bps)
    Flash Chip 0x00898982, Intel, Size: 64MBytes
    Processing "rm872__03.58.mcusw_ebl_psi.fls"...
    Sending Certificate...
    Certificate Accepted
    Erasing 0x40000000-0x4001FFFF...
    Flashing at 0x40000000...
    Flashed 131072 bytes OK
    Erasing 0x40040000-0x4005FFFF...
    Flashing at 0x40040000...
    Erasing 0x40060000-0x4015FFFF...
    Flashing at 0x40060000...
    Flashed 1048576 bytes OK
    Erasing 0x40280000-0x41A7FFFF...
    Flashing at 0x40280000...
    Flashed 25165824 bytes OK
    Erasing 0x43E20000-0x43E5FFFF...
    Processing rm872__03.58.ppm_s3 (XGold2)...
    Checking rm872__03.58.ppm_s3...
    Processing "package_s3.ppm_ebl_psi.fls"...
    Erasing 0x41A80000-0x420FFFFF...
    Flashing at 0x41A80000...
    Flashed 6251764 bytes OK
    Processing rm872__03.58.image_s3_059Q477 (XGold2)...
    Checking rm872__03.58.image_s3_059Q477...
    Processing "package_s3_059Q477.image.fls"...
    Erasing 0x42100000-0x43E1FFFF...
    Flashing at 0x42100000...
    Flashed 15597568 bytes OK
    Erasing 0x43E60000-0x43F3FFFF...
    All images processed OK! Processing post flash tasks...
    Setting Factory Defaults...
    [Nokia USB Phonet]: Port opened OK!
    Factory defaults OK
    Reading info...
    MCU Version V 03.58
    MCU Date 05-12-12
    Product RM-872 (Nokia RM-872)
    Manufacturer (c) Nokia
    IMEI 355902050084282
    Mastercode 4755251665
    IMEI Spare 3A55090205802408
    IMEI SV 3355090205802408F5000000
    PPM V 03.58, 05-12-12, RM-872, (c) Nokia , S3
    CNT Content: s3_059Q477, V 03.58, 05-12-12, RM-872, (c) Nokia
    PSN E4A9A1FAH
    Product Code 059Q426
    Module Code 0205283
    Basic Product Code 059P6H2
    PSD 0000000000000000
    LPSN 0
    HW 1600
    RFIC 68
    LCD TPO
    BT 19b5-22012
    Asic 11
    HW Signature ADB547A842D74DE1
    Simlock Server SIMLOCK SERVER
    Simlock Key 0010100000000000
    Simlock Profile 800000000004000B
    Simlock Aux 000B0000
    Simlock IMEI 00003559020500842800
    Simlock Key Cnt 0
    Simlock FBUS Cnt 0
    Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
    Simlock [1,2] State: OPENED Type: GID Data: FFFF
    Simlock [1,3] State: OPENED Type: GID Data: FFFF
    Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
    Simlock [2,2] State: OPENED Type: GID Data: FFFF
    Simlock [2,3] State: OPENED Type: GID Data: FFFF
    Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
    Simlock [3,2] State: OPENED Type: GID Data: FFFF
    Simlock [3,3] State: OPENED Type: GID Data: FFFF
    Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
    Simlock [4,2] State: OPENED Type: GID Data: FFFF
    Simlock [4,3] State: OPENED Type: GID Data: FFFF
    Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
    Simlock [5,2] State: OPENED Type: GID Data: FFFF
    Simlock [5,3] State: OPENED Type: GID Data: FFFF
    Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
    Simlock [6,2] State: OPENED Type: GID Data: FFFF
    Simlock [6,3] State: OPENED Type: GID Data: FFFF
    Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
    Simlock [7,2] State: OPENED Type: GID Data: FFFF
    Simlock [7,3] State: OPENED Type: GID Data: FFFF
    Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
    Read info thread finished, continuing...
    Post flash tasks finished!
    Flashing successfully finished!
    ĐìnhLập ,chuyên unlock,mở mạng,repair boot, chạy phần mềm,unlock all sl3,iphone.Cách bệnh viện huyện BaVì 200m đới diện cây xăng-cầu dấng ,km56-quốc lộ 32-vật lại-ba vì-hà nội.
  2. Các thành viên Cảm ơn bavi_gsm :
  3. #2
    V.I.P KHÁNHDUY@_FPT's Avatar
    Tham gia ngày
    Jan 2010
    Bài gởi
    5,336
    Con này BEST chắc mần ngọt .
  4. #3
    Tham gia ngày
    Jun 2011
    Bài gởi
    2,332
    Trích Nguyên văn bởi KHÁNHDUY@_FPT View Post
    best đều mần ngọt nhưng có con chạy nó cứ erro như hồi máy 3110c và 6300 qua jaf lại ok.mình post lên chia sẻ anh em chưa mần HW vội.
  5. #4
    Super Moderator H.Y.K's Avatar
    Tham gia ngày
    Jan 2007
    Bài gởi
    3,937
    Máy này hôm bữa dùng atf nạp tới file cnt được 99% thì nó báo flash fail,lấy ra bật nguồn thử chức năng ok luôn
    Hải Minh Mobile Service Center - Nhận đổi Seri Number vĩnh viễn cho iPhone 4
    Code SL3 giá 150k từ 1-6h-Code X3-02 Optus 20 nck-Code unlock iPhone/HTC/All giá rẻ cho ae Vietfones Yahoo: im_mpark
  6. #5
    Tham gia ngày
    Apr 2013
    Bài gởi
    60
    Uk. Toàn dùng best con nào cũng ok
  7. #6
    Senior Member Bảo Hân_Apple's Avatar
    Tham gia ngày
    May 2010
    Bài gởi
    2,124
    bt free ngọt lám ae....
  8. #7
    Tham gia ngày
    Jan 2010
    Bài gởi
    5,336
    Trích Nguyên văn bởi H.Y.K View Post
    Giống như jaf chạy 3110c song ok báo fail mà vẫn ok
  9. #8
    Tham gia ngày
    Jun 2011
    Bài gởi
    2,332
    con này nó chạy nửa chừng erro mà anh.
  10. #9
    Senior Member
    Tham gia ngày
    May 2011
    Bài gởi
    608
    con này chạy nhiều rồi atf là ok nhất
  11. #10
    Tham gia ngày
    Jun 2011
    Bài gởi
    2,332
    Trích Nguyên văn bởi thinh1982 View Post
    cái này là gặp trường hợp atf chạy không được mà,mình có bàn luộn gì đâu,chỉ là một chút kinh nghiệm muốn chia sẻ anh em.
+ Trả Lời Ðề Tài
