ThayKính ip6+Note4 | BánMáy+ÉpKính | LinhKiện MinhHải | LinhKiện ThảoDuy
MuaLCDBểKính | LinhKiện Công Anh | 260 Trường Chinh | Hải Minh iPhone
SAMSUNG | ThayKính+LkZinRẻ | VQ Ép Kính+LK | Trùm Sửa iPhone
Trang 1/3 123 cuốicuối
Kết quả từ 1 tới 10 trên 26
  1. #1
    Senior Member Hoanganhgsm's Avatar
    Tham gia ngày
    Nov 2011
    Bài gởi
    539
    như tiêu đề e nhận con 5130c bị contac e cho vào ATF chạy nhưng vẫn bị không hết, máy vẫn còn imei các bác làm qua giúp e với, e mới mua hộp ATF lên chưa biết chạy ah. thanks all
    log e nó đây ah
    Number of Image Files: 3
    Processing Image File :
    rm495__07.97.mcusw
    CMT Type : BB5
    CMT Algorithm : BB5 ALGORITHM
    Secondary Sending Speed : 3250000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 1178
    Entry Point: 0x5057
    Page Format : -1
    MAX PAGE : 0x00004000
    rm495__07.97.ppm_v
    CMT Type : BB5
    Number of Blocks : 494
    Entry Point: 0x00BE
    Page Format : -1
    rm495__07.97.image_v_red
    CMT Type : BB5
    Number of Blocks : 824
    Entry Point: 0x00D0
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    BootFlashModeDCT5Ex Succeeded First Time
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 030C1921
    ID DWORD 4 : 01033000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 11F0010C
    ID DWORD 1 : 227C7D56
    ID DWORD 2 : 8EE6B725
    ID DWORD 3 : F50D95FF
    ID DWORD 4 : 2FA7F66E
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    ADL_SERVER: PROCESSING rm495__07.97.mcusw
    ADL_SERVER: ROOT_KEY_HASH MATCH FOUND
    ADL_SERVER: CMT CERTIFICATE BLOCK FOUND
    ADL_SERVER: CMT DATA BLOCKS FOUND
    ADL_SERVER: CONSOLIDATING CMT BLOCKS
    ADL_SERVER: PASUBTOC BLOCK FOUND
    BB5 ADL Loader Start Up... (Please Wait...)
    Found Nokia BB5 ADL Loader USB Generic...
    Processing : rm495__07.97.mcusw
    Erase Block Found
    >> Erasing area 0x00000000 - 0x000006BF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x000006C0 - 0x0001FFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x00040000 - 0x000BFFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x000C0000 - 0x0013FFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x00140000 - 0x0137FFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x01380000 - 0x0151FFFF, Type: NOR , Subsystem: CMT
    Erase Complete : No Error - 0 (0x00)
    Data Block Found : 1178 Blocks
    >> CMT Rootkey Hash CERT : NOLO
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS [0C917F11196FDB7378C18EF7260698CA4489DCA0]
    >> CMT Rootkey Hash CERT : UPDAPP
    >> CMT Rootkey Hash CERT : DSP0
    >> CMT Rootkey Hash CERT : MCUSW
    Continue Flash Complete : No Error - 0 (0x00)
    Processing : rm495__07.97.ppm_v
    Erase Block Found
    >> Erasing area 0x01520000 - 0x01DBFFFF, Type: NOR , Subsystem: CMT
    Data Block Found : 494 Blocks
    Processing : rm495__07.97.image_v_red
    Erase Block Found
    >> Erasing area 0x01DC0000 - 0x0215FFFF, Type: NOR , Subsystem: CMT
    >> Erasing area 0x02160000 - 0x03FBFFFF, Type: NOR , Subsystem: CMT
    Data Block Found : 824 Blocks
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:08:09
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    SW: V 07.97 13-09-10 RM-495 (c) Nokia
    IMEI: 353223031687883
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SUPER_DONGLE_TEST : FAILED
    > REPAIR USING FBUS CABLE
    > Try "Customized SX4 with SD Repair"
    > Then Write PM 1 and 309
    SECURITY_CODE : 12345
    SL3 Phone detected
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    Nhận DK TTTB mạng Viettel ( sim học sinh)-Vinaphone cho tất cả ae -yahoo: bacgianggsm
    DT: 0977.017.028-02408505868 - Agribank:250.620.509.6520
  2. #2
    Senior Member vietfones gsm's Avatar
    Tham gia ngày
    Mar 2013
    Bài gởi
    37
    log liết đẹp thì backup rùi thay flash thôi anh
  3. Các thành viên Cảm ơn vietfones gsm :
  4. #3
    Senior Member Evil.13Fri's Avatar
    Tham gia ngày
    Jul 2010
    Bài gởi
    806
    Quăng log coi xem do FW hay HW
  5. Các thành viên Cảm ơn Evil.13Fri :
  6. #4
    Senior Member viettinh's Avatar
    Tham gia ngày
    Dec 2008
    Bài gởi
    1,956
    Cho cái log INFO rồi mấy anh ý phán cho mà mần.
  7. Các thành viên Cảm ơn viettinh :
  8. #5
    Tham gia ngày
    Nov 2011
    Bài gởi
    539
    e đang chạy pm ah .
  9. #6
    Trích Nguyên văn bởi Hoanganhgsm View Post
    e đang chạy pm ah .
    contacsevic chạy hết sao dc mang cái log lên đây xem còn repair được ko
  10. #7
    Senior Member N-H 09's Avatar
    Tham gia ngày
    Oct 2012
    Bài gởi
    667
    backup lại trước đi rồi nạp pm cho nó thường nó bị lỗi 309 đó bạn ui
  11. #8
    Tham gia ngày
    Nov 2011
    Bài gởi
    539
    đã có log ae vào giúp e với ah
  12. #9
    Senior Member duykhanh_gsm's Avatar
    Tham gia ngày
    May 2011
    Bài gởi
    1,163
    làm như box hướng dẫn đã
  13. #10
    Senior Member quoc_binhthuan's Avatar
    Tham gia ngày
    Jun 2011
    Bài gởi
    732
    thử write cho nó cái pm 1 & 309 chưa bạn
+ Trả Lời Ðề Tài
