Trang 1/5 123 ... cuốicuối
Kết quả từ 1 tới 10 trên 48
  1. #1
    Junior member
    Tham gia ngày
    Jul 2010
    Bài gởi
    182
    Its Work On All Android Also China Tablet
    What New ?
    User Manual for Android Multi Tools v1.02b
    first device must install correct driver
    This program works with any Android device .
    Requires root and enable Debug mode or fast boot mode.
    choice 1-6,S,H can work with Debug Mode only.
    choice 7-9 can work with Fastboot Mode only.
    choice detail
    1.Check Device for check connection of device to PC.
    2.Reset Face/PIN Lock for reset face lock on android 4.1.x and PIN lock without lost data.
    3.Reset Face/Gesture Lock for reset face lock on android 4.1.x and Gesture lock without lost data. After device reboot Then you can draw anything for unlock.don't forget close lock in security menu
    4.Reset GMail for reset gmail login after try many time wrong unlock
    5.Wipe Data for reset all data to factory setting.
    6.Reboot for reboot device to normal mode or exit from adb shell.
    7.Check Device On Fastboot Mode for check connection of device to on FastBoot mode.
    8.Wipe Data / Cache On Fastboot Mode for erase user datat and cache on Fastboot Mode to resolve freeze,stuk on boot logo or slow down device. That is often found in the CPU Spreadtrum SC6280/SC8810.
    9.Exit Fastboot Mode for reboot your PC or exit FastBoot.
    0.Go To Command Promt for entering DOS promt.you can use command in this soft folder And can return to the main program by type exit
    S.Software Info for info CPU inside,firmware version and etc.
    H.Hardware Info for determine the IC number of Gsensor,touch screen,Camera,WIFI and more
    R.Report / Contact Me links to the specific problems of the Phase I program and a bookmark.
    D.Driver Download for loading the drivers in case you do not have the driver installed in your PC
    E.Help for open this document
    O.Donate for open link to donate to my account
    Download:Android Multi Tools v1.02b Release
    Thêm video Cho pro tí :
  2. #2
    nhin màn hinh desktop mà khủng luôn trùm box nhỉ
  3. #3
    Senior Member Xung_iP's Avatar
    Tham gia ngày
    Dec 2012
    Bài gởi
    339
    chưa bit là ji tets thử cái xem sao
  4. #4
    Senior Member quoc_binhthuan's Avatar
    Tham gia ngày
    Jun 2011
    Bài gởi
    742
    đánh dấu cái hôm nào gặp test thử....tks bac
  5. #5
    Moderator Lâm_Spiderman's Avatar
    Tham gia ngày
    Sep 2009
    Bài gởi
    6,220
    file này về phần mềm diệt virus nó xử , ai mở ok thì comment nhé.
  6. #6
    Tham gia ngày
    Jun 2011
    Bài gởi
    742
    tắt phần mềm diệt virus đi bạn.....mình tắt ct virus mở ok mà
  7. #7
    Senior Member vietfones gsm's Avatar
    Tham gia ngày
    Mar 2013
    Bài gởi
    37
    Trích Nguyên văn bởi Lâm_Spiderman View Post
    mở ok mà mod nhện ơi
  8. #8
    Senior Member 0907318179's Avatar
    Tham gia ngày
    Mar 2011
    Bài gởi
    1,048
    đang có con A7100 CHINA không biết chơi được không ,thử rồi mà không nhận drive bác nào biết hướng dẫn em cái ,thanks all
  9. #9
    V.I.P KHÁNHDUY@_FPT's Avatar
    Tham gia ngày
    Jan 2010
    Bài gởi
    5,339
    Cũng Như Mod mở ra là nó múc .
  10. #10
    Senior Member Tmobile_VFS's Avatar
    Tham gia ngày
    Aug 2008
    Bài gởi
    1,308
    mở lên ok mà
    YM: chuahanquenem_net
    Tel: 0917777870
  11. Các thành viên Cảm ơn Tmobile_VFS :
Ðề tài đã khoá
