Kết quả từ 1 tới 3 trên 3
  1. #1
    Banned
    Tham gia ngày
    Nov 2008
    Bài gởi
    372
    e mới up lên bản mới chyaj toàn báo lỗi ae xin chỉ giúp
    Reading CMT PARTNERC (0x0 bytes).
    Waiting for USB device removal ...
    Waiting for device boot up ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3385C6E9
    Open device failed: FFFFFFFF (4) The system cannot open the file
    Warning: Phone did not reboot to normal mode.
    [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
  2. #2
    Junior member
    Tham gia ngày
    Mar 2009
    Bài gởi
    223
    hôm nay được rồi mà bạn mình mới làm được khi sáng
  3. #3
    Banned
    Tham gia ngày
    Nov 2008
    Bài gởi
    372
    ae xem thu cai log chạy gần hết báo lỗi
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 01007B9E
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    Processing MCU file: rm709__08.71.mcusw
    [BB5,XSR 1.6] size: 26.61 MB
    Supported Ids: 2200050920030000, 22000509200C0000
    Make sure USB cable, Battery and charger are removed from device.
    Insert USB cable, Battery back to device(make sure to have fully charged battery).
    Insert Charger or Press phone's power button(if flashing doesnt start automatically)
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
    CMT EM0 ID: 00005361
    CMT PUBLIC ID: 00000000004A7F33BFC77CB2C8C74A5D3AAF3979
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
    CMT ROM ID: DE56D582BDDE7A3A
    Loading CMT secondary boot code
    SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
    Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
    Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
    Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
    Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Loading CMT update server data
    Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
    Update server code loaded.
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2716F7CD
    FUR: Adding Asic CMT as client OK.
    Reading CMT NPC (0x168 bytes).
    Reading CMT VARIANT (0x0 bytes).
    Reading CMT CCC (0x160 bytes).
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Reading CMT MDM_KEYS (0x0 bytes).
    RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35741004054550_CE RT.rpl).
    CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
    Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 33.88 MB
    CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
    CMT FLASH,MuxOneNAND area [00020000-000203FF]
    CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
    CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
    CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
    Formating partition ...
    Flash programming ...
    CMT KEYS block sent
    CMT ADA block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 37955B6F [] sent
    CMT UPDAPP block sent
    CMT MCUSW block sent
    CMT MCUSW1 block sent
    CMT GENIO_INIT block sent
    CMT ISA+DYNSW block sent
    Programming completed in 9.860 s
    Processing PPM file: rm709__08.71.ppm_mk3
    [BB5,XSR 1.6] size: 6.80 MB
    Erase size: 8 MB
    CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
    Programming completed in 2.219 s
    Processing CNT file: rm709__08.71.image_mk3_059C3M8
    [BB5,XSR 1.6] size: 23.91 MB
    Erase size: 75.31 MB
    CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
    Programming completed in 8.172 s
    Total time for flashing process(boot+erase+write) was 29.672 s
+ Trả Lời Ðề Tài
