Kết quả từ 1 tới 2 trên 2
  1. #1
    Senior Member hieuthinh's Avatar
    Tham gia ngày
    Mar 2009
    Bài gởi
    441
    anh em nào làm rồi đừng chém tội em log em nó đây:
    Imei data is empty!
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0855D4B
    Using device: HTI, FW ver: 00.24, SN: 0000BC30
    Connection status: UHCI:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
    Do not disconnect or abort this operation otherwise phone will be damaged.
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.24
    EBL version : Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbps
    Flash ID: 00EC 2404 [Samsung ]
    Processing file: rm769_006.650
    Downloading item CODE:hw_f3_rm769_r06.650.fls, num block: 3, size: 5.58 MB
    Erasing area 0x00000000-0x00005FFE ...OK
    Programming completed in 0.891 s
    Erasing area 0x00800000-0x00BEFFFE ...OK
    Programming completed in 1 min 45.954 s
    Erasing area 0x00C5D000-0x00DFB6FE ...OK
    Programming completed in 43.093 s
    Checksum verified (0x5824)
    Processing file: rm769_006.65mr
    Downloading item CUST:hw_f3_rm769_006.65mr.fls, num block: 1, size: 5.07 MB
    Erasing area 0x00100000-0x006109FE ...OK
    Programming completed in 2 min 12.312 s
    Checksum verified (0x0D4B)
    Processing file: rm7690_nai06.65mr
    Downloading item CUST:hw_f3_rm7690_nai06.65mr.fls, num block: 1, size: 700.58 KB
    Erasing area 0x00E60000-0x00F0E53E ...OK
    Programming completed in 17.203 s
    Checksum verified (0xD33E)
    Total time for flashing process(boot+erase+write) was 6 min 58.531 s
    Phone type: RM-769
    SW version: V 06.65 07-11-11 RM-769 (c) Nokia
    Imei plain: 35906704237868-3
    Product code: 059H0D7
    Cellular system: GSM
    ASIC ID: 0x2292, type: 11
    Ppm Id: MR
    Language Pack:
    - not available.
    Master code: 6073415665
    Imei net: 35906704237868
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 0000000000040002
    BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    ĐTDĐ Nhựt Linh 0932 992992
  2. Các thành viên Cảm ơn hieuthinh :
  3. #2
    Senior Member Trần Quốc Lợi's Avatar
    Tham gia ngày
    Nov 2011
    Bài gởi
    624
    cảm ơn bạn đã chia sẽ.................................
  4. Các thành viên Cảm ơn Trần Quốc Lợi :
+ Trả Lời Ðề Tài
