ThayKính ip6+Note4 | BánMáy+ÉpKính | LinhKiện MinhHải | LinhKiện ThảoDuy
MuaLCDBểKính | LinhKiện Công Anh | 260 Trường Chinh | Hải Minh iPhone
SAMSUNG | ThayKính+LkZinRẻ | VQ Ép Kính+LK | Trùm Sửa iPhone
Kết quả từ 1 tới 4 trên 4
  1. #1
    Senior Member PHÚ THỌ's Avatar
    Tham gia ngày
    Nov 2010
    Bài gởi
    815
    các anh flash con nài ok qua mx key chưa ạ. em mới mở mã bảo vệ. hôm nay có mát chạy mà nó không chạy được ạ.
    Imei data is empty!
    MXKEY Serial: [FT SCR2000 0] - C0849803
    Using device: UFS_USB V2.8 (c) SarasSoft 2007.
    Driver: uhci:hub:UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0
    Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011)
    Do not disconnect or abort this operation otherwise phone will be damaged.
    Device synchronized.
    CPU: XGOLD 110
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.24
    EBL version : Default_RAM_Bootloader
    Set baud rate to: 921600
    Flash ID: 00EC 2404 [Samsung ]
    Processing file: rm713_005.290
    Downloading item CODE:hw_b1_rm713_r05.290.fls, num block: 3, size: 5.58 MB
    Erasing area 0x00000018-0x00170000 ...
    Hotline: 0974.225.111
    Mobile: 0964.39.2286
    Yh: langtham_pt
  2. #2
    Tham gia ngày
    Nov 2010
    Bài gởi
    815
    ai qua giúp em với ạ.
    log scan vẫn được.
    Phone Type: RM-713
    SW Version: V 05.29 10-06-11 RM-713 (c) Nokia
    Imei plain: 35829204384656-8
    Product Code: 059G464
    Cellular System: GSM
    ASIC ID: 0x2292, type: 11
    Ppm Id: MR
    Language Pack:
    - not available.
    Imei net: 35829204384656
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 0000000000030002
    BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    FULL FACTORY... Failed!
    Completed in 0.578 s
    FULL FACTORY... OK
    USER DATA... Failed!
    Completed in 0.641 s
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 3.703 s
    Yh: langtham_pt
  3. #3
    Senior Member Tuấn Phong's Avatar
    Tham gia ngày
    Jul 2010
    Bài gởi
    499
    Read code luôn sao phải chạy cho mệt
  4. #4
    Senior Member hưngthumobile's Avatar
    Tham gia ngày
    May 2009
    Bài gởi
    360
    cái này nhập sai quá nhiều lần nên như vậy! tắt nguồn rồi cắm sạc tầm 1 tiếng chạy lại ok
    UNLOCK-NẠP PHẦN MỀM-LÀM PHẦN CỨNG ALL MOBILE
    ĐÀO TẠO HỌC VIÊN
    mobile :0967 666 836
    yahoo :hungthu_gsm
+ Trả Lời Ðề Tài
